Title | Size | Downloads |
04-Layer 3 - IP Services Command Reference-book.pdf | 1.09 MB |
Preface
The H3C S5500-SI/EI documentation set includes 10 command references, which describe the commands and command syntax options for the S5500-SI and S5500-EI series Ethernet switches, Release2208.
The Layer 3—IP Services Command Reference describes the commands for configuring IP addressing, DHCP, IP performance optimization, ARP, DNS, UDP helper, IRDP, IPv6 basics, DHCPv6 and IPv4-IPv6 transitional technologies.
This preface includes:
· Audience
· About the H3C S5500-SI/EI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-SI/EI series
Added and modified commands
Compared to Release2202, Release2208 adds, modifies, and deletes the following commands:
Command reference |
Added and modified commands |
ARP configuration |
Added commands: arp send-gratuitous-arp [ interval milliseconds ] |
Proxy ARP configuration |
Modified commands: local-proxy-arp enable [ ip-range startIP to endIP ]—modified from local-proxy-arp enable |
IP addressing |
Added commands: ip address unnumbered interface interface-type interface-number(available only on the S5500-EI) |
DHCP server configuration |
S5500-EI |
Added commands: Modified commands: · undo dhcp server ip-pool pool-name—Modified from undo dhcp server ip-pool pool-name [ extended ] · undo network ip range—Modified from undo network ip range [ min-address max-address ] · undo network mask—Modified from undo network mask [ mask ] |
S5500-SI |
Added commands: DHCP server configuration related commands. |
DHCP relay agent configuration |
Added commands: · dhcp relay check mac-address · dhcp relay client-detect enable |
DHCP client configuration |
DHCP snooping configuration |
· dhcp-snooping binding database filename · dhcp-snooping binding database update interval · dhcp-snooping binding database update now · dhcp-snooping check mac-address · dhcp-snooping check request-message · display dhcp-snooping binding database |
BOOTP client configuration |
IPv4 DNS configuration |
Added commands: · dns spoofing Modified commands: · display dns host—Modified from display dns dynamic-host · dns server (available in interface view) · reset dns host—Modified from reset dns dynamic-host |
IPv6 DNS configuration |
IP performance optimization |
IRDP |
IRDP configuration commands are all newly added. |
UDP Helper |
IPv6 basics |
Added commands: · ND snooping related commands · ND proxy related commands · ipv6 nd ra no-advlinkmtu · ipv6 prefer temporary-address · ipv6 unreachables enable |
DHCPv6 |
DHCPv6 configuration commands are all newly added. |
Tunneling(available only on the S5500-EI) |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
The H3C S5500-SI/EI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
PSR150-A [ PSR150-D ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
RPS User Manual |
Describes the appearances, features, and specifications of the RPS units available for the products. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Interface Card User Manual |
Describes interface card appearance and specifications. |
Hardware installation |
Quick Start |
Provides regulatory information and the safety instructions that must be followed during installation. Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Installation Guide |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes how to install an interface card. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C Series Ethernet Switches Login Password Recovery Manual |
Describes how to find or recover a lost password. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
